Mit dabei seit Ende 2009 Wohnort: Prague, Czech Republic Status: Verschollen
...und hat diesen Thread vor 5995 Tagen gestartet!
| Fahrzeuge 1. Toyota Land Cruiser HZJ78, Toyota Hilux 2,4TD LN105, LRSII Pickup |
Verfasst am: 28.10.2009 14:58:34 Titel: CPRO parts |
spacer adapters 30mm
LR Defender 90,110,130, LR Discovery 1, RR Classic
LR Discovery 2, RR P38
LR Discovery 3, RR 3
LR Freelander
Hub Adaptor 70mm Spigot
Allows fitting of Discovery 2/3 wheels to LR Discovery 1 and Land Rover Defender, Rover Classic
Spigot Adaptor Rings
Adapts 70 mm spigot to 72.5 mm
Adaptor 30mm to fit LR Discovery 2/3 axle with Defender wheels
LR stud – M16x1,5 / M14x1,5 / M12x1,5
Radiator – coolant filler brass plug with O-ring seal (Corresponding to part No: ERR4686)
Will fit:
Land Rover DEFENDER 90, 110, 127, 130
Land Rover DISCOVERY 1, 2
Rover CLASSIC
Land Rover Stage One V8
Note:
Enhance the reliability of your vehicle by replacing the weak plastic radiator plug or fill plugs with this solid-brass version. This plug is direct, drop-in replacement for the weak plastic radiator plugs fitted to older Land Rovers, and also the fill plugs on the Disco2 and P38 Rover .
Brass bleed screw Td5 (cooling system) (Corresponding to part No: PYP10008L)
Note:
Enhance the reliability of your vehicle by replacing the weak plastic bleed screw with this solid-brass version. This screw is direct, drop-in replacement for the weak plastic bleed screw fitted to all Land Rover vehicles with Td5 engine
Window guards for LR Defender SW / LR Defender pickup
rear side, quarter windows at rear , back door with option of cut out for high level brake if required (option of internal or external)
Info - www.cpro.cz
Jan Prochazka / Prague / Czech Republic
| Beschreibung: |
| Dateigröße: |
111.67 KB |
| Angeschaut: |
2581 mal |
| Beschreibung: |
 Download |
| Dateiname: |
LR_WS_4.jpg |
| Dateigröße: |
207.45 KB |
| Heruntergeladen: |
407 mal |
| Beschreibung: |
 Download |
| Dateiname: |
GG_1.jpg |
| Dateigröße: |
211.82 KB |
| Heruntergeladen: |
418 mal |
| Beschreibung: |
 Download |
| Dateiname: |
BP_1.jpg |
| Dateigröße: |
138.43 KB |
| Heruntergeladen: |
401 mal |
| Beschreibung: |
 Download |
| Dateiname: |
BS_TD5A.jpg |
| Dateigröße: |
160.7 KB |
| Heruntergeladen: |
370 mal |
Verfasst am: 29.01.2010 10:32:45 Titel: News - stainless steel front caliper piston |
News - stainless steel front caliper piston for Land Rover Defender 90, LR Discovery 1, Rover Classic - dia 41,2 mm / Part No. 606683, CNC machining - excellent quality and low price (Made in Czech Republic) / www.cpro.cz
Verfasst am: 29.01.2010 10:38:07 Titel: News - Rear Disclocation Cones |
Rear Disclocation Cones (pair). To fit Disco 1, Rover Classic and Defender 90
Made in Czech Republic - www.cpro.cz
Verfasst am: 31.01.2010 22:54:46 Titel: NEWS - Hub Adaptor 70mm Spigot |
Allows fitting of Discovery 2/3 wheels to LR Discovery 1 and Land Rover Defender, Rover Classic with Spigot Adaptor Rings
 benachbarter Haubenpopper
Mit dabei seit Mitte 2005 Wohnort: Bayern
| Fahrzeuge 1. 90er TD5  2. Discovery 3  3. Audi A3 2.0TDI quattro  4. Audi A4 2.0TDI Allroad  5. ZAR57  |
Verfasst am: 01.02.2010 11:18:07 Titel: |
gibts auch preise? are there any prices?
| _________________ ...wer ohne Narrheit lebt ist nicht so weise wie er glaubt!! :-)
Mit dabei seit Anfang 2008 Wohnort: Bad Klosterlausnitz Status: Verschollen
| Fahrzeuge 1. LR D110 SW TD5 2. BMW 1150 GS 3. IHC D-439 |
Verfasst am: 03.02.2010 19:20:56 Titel: |
Prices? No way! Why..???
| _________________ Mach`s halt! |
