Here's a list of terms I found on 't interweb.
There are a good number of terms that are more or less obsolete as they are replaced by more up to date ones like Accumulator - battery, These days the English mostly use the word battery as wel.
British term American term
accumulator (battery) battery
actuator switch or servo
Artic (articulated lorry) tractor-trailer or 18 wheeler
baulk ring synchro ring
bonnet hood
boot trunk
bulkhead firewall
choke tube venturi
core plug freeze plug
crocodile clip alligator clip
crosshead Phillips
crown ring gear
cubby box glove box or glove compartment
damper shock absorber
drive shaft half shaft or
drop-head coupe convertible version of 2 door coupe
dumpy screwdriver (stubby) short screwdriver
dynamo (Alternator) generator
earth ground
Exhaust manifold Header or collector
estate station wagon
fascia dashboard
fixed-head coupe 2 door coupe
frogeye bugeye
Gallon (Imperial) 5 US Quarts
gearbox transmission
gudgeon pin wrist pin
hood convertible top (sft top)
jointing compound gasket sealant
lorry truck
mole wrench Vice grips
monocoque unibody
Ministry of Transport Department of Transportation
nave plate hubcap
nose front of car
paraffin kerosene
pinking knocking or pinging
prop shaft drive shaft
petrol gasoline
prise pry
proud above or raised
quarterlight vent window
rev counter tachometer
ring gear flywheel gear, or starter gear
roadster car that only comes in a convertible style
roundabout rotary, traffic circle
RoStyle type of steel (as opposed to wire)
saloon 2 or 4 door sedan
scuttle cowl
side curtains removable side windows
silencer muffler
sill rocker panel
Shooting Brake station wagon
spanner wrench
split pin cotter pin
spring washer lock washer
squab part of seat
suction advance vacuum advance
sump oil pan
thrust bearing throwout bearing
tickover idle
Tow bar Hitch
top gear high gear
torch flashlight
trunnion sliding or rotating joint (suspension)
nut lug nut
whitworth Brtish thread measuring standard
windscreen windshield
wing fender
Feel free to add to this list.
Oh bollocks ! I had it all spaced out but this shoddy website ain't having it !
