Different stages of build a Nissan.
56k beware, Big pics.
bacho
manic mechanic
...und hat diesen Thread vor 7249 Tagen gestartet!
BeitragVerfasst am: 03.12.2006 19:21:35    Titel: Different stages of build a Nissan.
I thought I would try to make a little something on how my nissan was built, I have done a couple major things to it. First I did a trailmaster lift with a Coil-Over IFS set-up. Then I did the long-arm mod that few pathys have over here.
This is the Coil-Over IFS set-up, I dont have many pics of it because there is a pending deal to put this into production. This mod can only be done with a trailmaster or equivelent drop kit.
The reason I did this mod was becuase I wanted a little more lfit without having to use a body lift. And with the drop kit it left the t-bars hanging low under the belly of the pathfinder. As seen in this pic
Wth the Coil-Over set-up I was able to remove the torsion bars and gain some more break-over angle.
About the same time I decided on the mod for the rear links because my upper links were maxed out with the 7" lift I had. I followed the general idea in this thread
http://nissan4wheelers.com/eve/forums/a/tpc/f/885603133/m/83110436221
It had plenty of travel in the back now.
All the mods to this point had been for a project in school, so to test my pathfinder as a final product I headed out to Moab Utah for Easter Jeep Safari. The trip was awesome and the pathfinder did well but I did find some weekness in it. The rear suspension liked to unload going down hill, which mostly just made things a little more hair raising. I found that the IFS just isnt suited to rock crawling, or at least not without much more work. So the whole time I was there I continually checked out other peoples trucks and watched how they worked. On the last day I pretxled the rear links in a dumb way, I had forgotten to build heavy duty ones.
Once I got home I decided an SAS and new rear suspension would have to be built. The first thing I did was replace the old lower links with some beefy ones made out of .375 wall 2" tube with Johny joints.
Then I started on the front. I picked up a Dana 44 axle from a waggoneer and cut all my IFS off and started going from there. I moved the axle forward about 4" and gave myself enough room to easily stuff a 39" tire, at least away from the firewall.
I used a radius arm set-up to keep it as low as possible. All links, tierod and drag link are 1.75"x.375 DOM tubing. I used a steering box out of a 1989 toyota 4-runner because I could easly tapp it for hydro assist steering and becuase the nissan one was simply worn out. The 10" Fox coil-ovesr I had before were not long enough for what I wanted so I found a deal on some 14" Walker Evans coil-overs.
After a couple flex tests showed everythign was good I welded everthing up.
Then the axle got yanked and I built it with 5.13 gears, ARB locker, Yukon chromoly shafts, OX joints with super Winch hubs. I also used hy-steer on this axle.
That leads me to today, I decided the ARB bumper was too big and hurt my approach angle so I sold it and I am working on a new Winch mount.
I am better at answering questions so if you want to know more details just ask. All of this has been done in a one year time frame starting last november, so most of it is fresh.
I have heard rumors of a Coil-Over IFS kit being availble in Germany, can anyone give more details about that?
BeitragVerfasst am: 03.12.2006 19:23:53    Titel:
wow Respekt
BeitragVerfasst am: 03.12.2006 20:23:05    Titel:
Damn impressive YES YES YES
Absolutely crazy, nice and wonderful buildup Respekt
Do you have any more informations about the Evan Walker Coilover-Suspension-Shocks?
In Spring 2007, I´ll swap an Dana 44 (even with Yukon Axle-Kit and stronger U-Joints) under my Jeep ZJ and I´m still not sure, which Coilover-system to choose. Heiligenschein
Thanks a lot for the pics Winke Winke
bacho
manic mechanic
BeitragVerfasst am: 03.12.2006 20:31:24    Titel:
The Walker Evans are a little cheaper than the Fox, King, Sway-Away Coil-Over shocks. Mostly because the dual rate kit for the springs is included. Not too many people have Walker Evans stuff so I was kinda in the dark when I bought them. I found the qualitly to be OK, but the finish was not up to par with the Fox shocks I had before. It was mostly that the Heim joints appeared to be cheaper. However, the shocks work well on the street and trail once you get them tuned for your application. And the customer service at Walker Evans is excellent.
The only thing to remember that Walker Evans stuff maxes at 14" of travel, so if you have big plans and want 16 or 18" I recomend looking at Sway-Away shocks because they are the next cheapest. Because all these shocks are fully rebuildable I recomend deciding how much travel you want, and look for used shocks. Good way to save a little money.
BeitragVerfasst am: 03.12.2006 20:43:22    Titel:
I'm a little in doubt whether the Nissan crowd here at the forum can help you with your very fine buildup, I bet most of them could learn a lot out of the Photos above..... Ich muss weg
Respekt
BeitragVerfasst am: 03.12.2006 20:46:14    Titel:
The Jeep I´m currently buildung up, will primary be used for desert rallyes in Africa Heiligenschein
So I don´t need so much travel. 14" should be enough. Ja
Are the evan walker rebuildable too? I´m not sure, that "theese shocks" include or exclude the walkers in your last sentence Unsicher
Do you now a good dealer for the Evans? Winke Winke
By the way - Here is my project: http://www.offroad-forum.de/viewtopic.php?t=8668
Edit: I agree SpeedyB - Think, we´ll learn from you, not in opposite Heiligenschein
el Che
Extremfrager
1. VW T4
BeitragVerfasst am: 03.12.2006 21:00:34    Titel:
mal schauen obs mit der Übersetzung hinkommt!
Was hast du gfr federn und federsitze genommen auf den bild?
What hav you useed vor Coil end Coilsitz in this Pictur?
and wha is the Coil in the Rear Axel ??
Was ist das für einefeder an der hinterachse
My Prject
http://www.offroad-forum.de/viewtopic.php?t=8930
gruß
bacho
manic mechanic
BeitragVerfasst am: 03.12.2006 21:01:52    Titel:
As in rebuildable I was meaning all of the major Coil-Over shock names, Walker Evans, Fox, King, Sway-Away, Rancho and Bilstein.
The ZJ project is cool, I havent translated it yet. So long as you build a stout cage to tie in the suspension around the unibody you will be in good shape.
bacho
manic mechanic
BeitragVerfasst am: 03.12.2006 21:19:07    Titel:
My Prject
My translation of that was a little rough. The front of that pathfinder uses 3.5" lift early Bronco springs. He used coil buckets off of a Ford Bronco. The radius arms are also off a Ford Bronco.
In the back he used 5.5 lift Bronco springs.
Meine übersetzung von der war ein wenig rauhes. Frontseite dieses Pfadfinders verwendet 3.5 " Spulen von einem frühen Bronco. Sie benutzte Spule Wannen weg durch Ford ein Bronco. Die Radiusarme sind auch von Ford ein Bronco weg. In der Rückseite benutzte er 5.5 Spulen von einem frühen Bronco.
BeitragVerfasst am: 03.12.2006 21:28:36    Titel:
bacho hat folgendes geschrieben:
Perfect...Will have a look for Evan Walkers on the net Grins
I know - Hard work to do. Uniframe stiffening is a long job and weight have to be always in my mind, because every pound counts in sand. But a plan for the front already exists and is a construction, which connects the Upper Control-Arm-Mounts to the stock shock-Mount, via the spring-coil-dome to the front Bumper. This whole construction should split the impact-forces in a rallye wide over the uniframe and provide enough strength for the Coilover. Ja
Hopefully... Hau mich, ich bin der Frühling
BeitragVerfasst am: 13.12.2006 22:37:33    Titel:
It seems to be impossible to find something about this brand in the net? Is it written correctly? Can anyone help me, finding the website of evan walkers? Unsicher
Strada
BeitragVerfasst am: 13.12.2006 22:48:25    Titel:
Und wie wäre es damit, mein meister Euer Wunsch sei mir Befehl
http://www.walkerevansracing.com/
BeitragVerfasst am: 13.12.2006 22:50:28    Titel:
Leninorden YES
Strada
BeitragVerfasst am: 13.12.2006 23:02:08    Titel:
Hast mir ja auch schon oft genug geholfen!
BeitragVerfasst am: 13.12.2006 23:05:18    Titel:
Traumhaft...Ich shoppe gerade virtuell schön passende Dämpfer O lappaloma blanke, i am just a bird in the sky
Werde mal anfragen, was mit Shipping to DE ist. Grins
23085731 Angriffe abgewehrt
Zeit für Seitenerstellung: 0.338  Sekunden
