 I'm.. waiting for my truck......
Mit dabei seit Ende 2006 Wohnort: GV Busch Status: Verschollen
...und hat diesen Thread vor 6716 Tagen gestartet!
| Fahrzeuge 1. MAN 8.150 FAE 2. Ford Ranger Wildtrak 3. Mountainbike 4. Lowa |
Verfasst am: 03.01.2008 18:31:36 Titel: 3 x armored Nissan Patrol STD ,1 x Nissan Patrol GL |
Folgende Fahrzeuge stehen zum Verkauf:
These vehicles are especially designed for rough conditions on the African continent.
I recommend to take this fully certified vehicle compared to a Toyota LC 105.
Availibility of:
•3 x armored STD
•1 x GL
Delivery: ex stock Dubai
Payment: 100% prior to delivery
Prices: 60.000 Euro each, but if all 5 are purchased discount will be given. All Prices net
Validity: 30 days, subject to being unsold from
Endusercertification: needs to be provided by the client
Mileages: All vehicles are below 6.000km
Services: Vehicles were running in a fleet and were well maintained and serviced
Production year: 2003-2004
Armour package:
Fully certified in level VR6, incl. explosion test by German ballistic institution.
Road performance:
Fully tested and certified by German WTD1. The vehicle suspension/brakes and all necessary chassis mounting points are adjusted to the additional weight. Wheelhouses, columns posts and hinges were exchanged and/or reinforced by heavy duty parts.
Engine:
The engine is perfect for rough terrain and hot regions, because of the simplicity. The engine is not turbo charged and would not stop running by the use of not perfect fuel.
Vehicle interior:
The interior has been set up to a max of security with a long lifetime by hard use. The armoured cage inside were covered with synthetic leather in a simple style to keep the max space inside for the passengers. The complete interior has been armoured incl. The luggage compartment.
Special equipment / Security related features
Explosafe fuel tank
The high-tech construction of the "Explosafe" tank prevents the fuel from explosions when projectiles hit the fuel tank
Run-flat tires
These tires enable the driver to maintain control over the car even if they are completely deflated and continue to drive for up to 80 km (incl. a full replacement fifth wheel)
Heatable windscreen and rear windows
Integrated heating filaments prevent the build-up of damp condensation and ensure that the thick panes of bullet-proof glass are quickly de-iced in cold weather.
Shockabsorbers front and rear are changed to a solution which is capable for 4.2 tons
Springs front and rear are changed to a solution which is capable for 4.2 tons
Front fenders and houses Are reinforced to strengthen body for additional weight
Additional reinforcements to hinge facing at pillars and doors
Door-centring wedges/supports on all 5 doors
Additional reinforcements hood support
Hutchinson Runflat system on 5 wheels (Max. distance after puncture 80 km. at 80km/h)
Four additional connection and carrying points Between chassis and body are added
The passenger compartment Is armored from all sides including door gap overlaps by ultra hardened armouring steel.
The floor and roof covers 2*DM51 hand grenades.
The whole vehicle was tested and certified according Vehicle Resistance Class VR6, carried out at a full vehicle with shooting and explosives (Hand grenades, 2*DM51)
Base vehicle specifications
Nissan STD (4) & Nissan GL (1)
general information:
Left-hand-drive
country of origin: Japan
number of doors: 5 engine:
fuel type: diesel
engine displacement (cc): 4,169
engine (cyl): 6, OHV
engine power (hp/rpm): 115/4,000
fuel tank capacity (L): 95
seating:
number of seats: 6 (5seats for GL)
upholstery: PVC cloth transmission:
5 speed manual
transmission
5 speed manual
transmission
standard equipment:
air conditioner automatic automatic
power steering Yes Yes
head rests Front 1st/2nd row
mud guards: front/rear 1st/2nd row
seat belts: 1st/2nd 1st/2nd
free running hub manual automatic
radio/casette MW/FM w.2 spkrs
warning triangle Yes
extra tank:40 litres Yes
wiper front 2 speed intermittent 2 speed intermittent
horn: double tone double tone
steering lock Yes
sun visors (2)
glove box with lock Yes
Door mirrors manual eectric
fuel filler lid opener Yes
fuel filter cap w/out key Yes
cigar lighter/ashtray Yes
spare w/jack Yes
standard tool set Yes
Owners manual Yes
tilt + collapsible steering Yes
Windscreen washer windows Yes
Door panels: Steel
covered with cloth Yes
Heated rear door windows yes
Power window driver Yes
high altitude
compensator
brakes/tyres/suspension:
brakes front: disc disc
brakes rear: drum drum
front: 235/80R16 235/80R16
rear: 235/80R16 235/80R16
Painted Alloy rims 8.0x16JJ 8.0x16JJ
measurements:
curb weight (kgs): 3,700
length (mm): 5,010
width (mm): 1,840
height (mm): 1,855
ground clearance (mm): 215
weitere Infos per PN oder Email
Tom | _________________ Pinkel niemals einem alten Jäger in die Flinten und behaupte es regnet. |
Verfasst am: 10.01.2008 09:09:19 Titel: |
Die Fahrzeuge sind verkauft !!  | _________________ Pinkel niemals einem alten Jäger in die Flinten und behaupte es regnet. |
Mit dabei seit Mitte 2007 Wohnort: hamburg Status: Verschollen
| Fahrzeuge 1. Nissan Patrol gr y60:Audi rs4 MTM 500 ps: Mv agusta F4 1000 |
Verfasst am: 13.01.2008 03:28:16 Titel: |
nach russland oder?!  | |
Verfasst am: 14.01.2008 11:27:07 Titel: |
Nein in eine warme Region.
Weitere Fahrzeuge in ein paar Wochen. | _________________ Pinkel niemals einem alten Jäger in die Flinten und behaupte es regnet. |
