461.3 manual
Jürgen_KSK
...und hat diesen Thread vor 6103 Tagen gestartet!
1. STEYR DAIMLER PUCH 300GDN
BeitragVerfasst am: 05.08.2009 13:59:46    Titel: 461.3 manual
anyone has got a basic manual of 461.3? I wonder how to do maintanance, what oil to use etc. I've only got list of spare parts for my older PUCH 300GD.
not mention I wonder, what the letters on the shifting lever means:
 Dateigröße:  231.96 KB
 Angeschaut:  7024 mal
BeitragVerfasst am: 05.08.2009 14:08:18    Titel:
S = Street (2WD Hi - 1:1)
SA = Street AllWheelDrive (4WD locked, 1:1)
N = Neutral
GA = Offroad AllWheelDrive (4WD low locked)
The letters came from german. GA means Gelände-Allrad and SA Strassen-Allrad.
BeitragVerfasst am: 05.08.2009 14:13:59    Titel:
Anyway - Oil-Specs from older W460 and W461 are equal. Means axles, split-case, transmission (remind the difference between automatic tranny and manual gearbox), steering, braking - all the same. Engine: Which one you got? Just use an oil corresponding to yours. Winke Winke
hubsi
1. Puch 290GD, Unimog 406
BeitragVerfasst am: 05.08.2009 14:15:07    Titel:
hello jürgen
s = 2x4
SA = 4x4 high
GA = 4x4 low
N = neutral
G-rüße aus Österreich
Hubsi
Jürgen_KSK
BeitragVerfasst am: 05.08.2009 14:23:30    Titel:
N = Neutral
why is double "SA" on the lever? And what means "low" and "hi" in terms of locking?
BeitragVerfasst am: 05.08.2009 14:27:11    Titel:
Jürgen_KSK hat folgendes geschrieben:
N = Neutral
Nope. Means that the split-case doesn´t care, if you pull the lever left or right :-)
Try moving it - There´s no noticable switching action.
Due to no real Differential function, 4x4 Hi and 4x4 Low are always locked. Low means reduction (2.14:1) = more torque, Hi means normal passthrough of power and torque (1:1).
Jürgen_KSK
BeitragVerfasst am: 05.08.2009 15:26:25    Titel:
Thank you very much, it helped me a lot! :)
anyway, any downloadable 461.3 manual would be very appreciated :) Any one got it?
BeitragVerfasst am: 05.08.2009 15:28:19    Titel:
No, ´cause it´s protected by a lot of copyrights and distribution of such download-links is strictly forbidden here Ja
Jürgen_KSK
BeitragVerfasst am: 05.08.2009 15:33:11    Titel:
Ok, I didn!t know that...
Well, I understand, thank you anyway.
Jürgen_KSK
BeitragVerfasst am: 10.08.2009 09:45:54    Titel:
another question...
what does this bottom/lever do? Unsicher
 Dateiname:  lever.jpg
 Dateigröße:  357.8 KB
 Heruntergeladen:  456 mal
BeitragVerfasst am: 10.08.2009 10:09:17    Titel:
Congratulations - You have a rear Differential lock Grins
Jürgen_KSK
BeitragVerfasst am: 10.08.2009 10:17:11    Titel:
So I can lock rear Differential whenever I want to, independetly on actual control lever position?
BeitragVerfasst am: 10.08.2009 10:19:20    Titel:
Yes sir Euer Wunsch sei mir Befehl
It´s working with hydraulic cylinders. Just pull it up and a ligt in your dashboard will show that´s locked.
But remember: Do not active under heavy load. Wait for a situation, where engagement is safe.
Jürgen_KSK
BeitragVerfasst am: 10.08.2009 10:36:01    Titel:
Actually what are the basic rules for using this options:
- S = Street (2WD Hi - 1:1)
- SA = Street AllWheelDrive (4WD locked, 1:1)
- N = Neutral
- GA = Offroad AllWheelDrive (4WD low locked)
- Rear Diff. locked
I mean, what max. speed is recommended, what load acceptable, in which terrain to use it... generally
BeitragVerfasst am: 10.08.2009 10:42:57    Titel:
Sorry, some of these basics do not belong to the car itself. It´s your part to get more familiar with offroading.
But some are easy.
Switch Split-Case only while standing still or at low speed with deactivating the clutch of transmission. Engage Diff-Lock only while rolling without traction-problems. e.g. on flat surface and always without a pressed gas-pedal :-)
Or generally: If your driving offroad, don´t touch anything. Stop for switching Split-Case or Diff-Lock. The split-case ion your G is synchronized (lika a tranny), but do not underestimate ne need for practicing such shifts ... Ja
Neues Thema eröffnen   Neue Antwort erstellen    Offroad Forum Foren-Übersicht -> Mercedes Gehe zu Seite 1, 2  Weiter =>
407868 Angriffe abgewehrt
Zeit für Seitenerstellung: 0.294  Sekunden
