inner plastic fender 460
Will they fit on a 461 - 95 modell
nielsa
...und hat diesen Thread vor 5974 Tagen gestartet!
BeitragVerfasst am: 13.12.2009 08:30:28    Titel: inner plastic fender 460
Hello!
Found these parts at www.helhans.de
Part numbers of the inner plastic fenders:
front left : 463 884 0222 approx. 47 Euro + TAX
front right : 463 884 0322
rear left : 463 884 0722 approx 53 Euro + Tax
rear right : 463 884 0622
Will they fit my 95 modell 461???
wbr
nielsa
w460fan
1. W460 GE280 daily drive
2. W460 GE230 verkauft
3. W460 GD300 im Koma
4. W163 270CDI fuer's Frauchen
BeitragVerfasst am: 13.12.2009 17:01:44    Titel:
hi there,
they do fit, but there're different one's for SWB and LWB, at least the rear ones are different in SWB/LWB.
hans fit them in his W460.
he made his own brakets and also fit them with tex-screws.
i did a simular job on my w460 as well.
the body of the w461 is actually the same as from the w460.
i've done it in about 4 hours on a sunday afternoon.
good luck.
cya
You can go fast!! I can go anywhere...
nielsa
BeitragVerfasst am: 15.12.2009 08:33:58    Titel:
Are the plastic fenders delivered in two different withs??.
My 290GD-95 has expanded plastic fenders on each side which demands some more with from the inner plastic fender to cover all the way to the outside.
wbr
nielsa
w460fan
BeitragVerfasst am: 16.12.2009 10:05:58    Titel:
hi,
no, they are not comin' in different width's.
the plastic arches should be sealed to the wing with rubber tape or simular.
the inner fender shall only protect the wing etc from water which appears due to the tires.
no panic, fit them and it will be fine.
i have used tex-screws and washers made from stainless steel as well.
i have also sealed the "hole" for the screw in the original fender with bitumius sealent, so even there, water/moisture has no chance to crawl in.
silicon may does the trick as welll, but silicon gets hard and cracky after a while under extreme circumstances, as it is not made for such things.
cya
407875 Angriffe abgewehrt
Zeit für Seitenerstellung: 0.159  Sekunden
