Netter ZJ
Strada
...und hat diesen Thread vor 6959 Tagen gestartet!
BeitragVerfasst am: 09.05.2007 13:40:02    Titel: Netter ZJ
Ja, es ist zwar Ami-typisch oversized, aber es gefällt mir trotzdem Love it Love it
http://www.nagca.com/forum/viewtopic.php?t=26790&postdays=0&postorder=asc&start=0
qFlashi
AUS!!!Nicht am Umbau mekern Ätsch rotfl
BeitragVerfasst am: 09.05.2007 13:50:45    Titel:
Nur mit Login sichtbar Hau mich, ich bin der Frühling
Strada
BeitragVerfasst am: 09.05.2007 13:58:28    Titel:
Ohh, Unsicher Unsicher
Jedenfalls ist da ein ZJ mit Fullwiths und 42er zu sehen, hier ein paar Foddos:
*edit*
Ich hab´s mal kopiert:
AprilzWarrior hat folgendes geschrieben:
Drum Roll please…
Here she is… standing at 7’ tall, 85” wide.
Wimpy 30 in the background
Nice 33”
Ground Clearance
The rear needs to drop almost 1”, need to relocated the rear coil mounts about 3” toward the tail lights…
Still to extend rear axle…drive lines… bleed brakes, all steering, front track bar.
AW
some pics from today...
I had to refab ALL 4 rear long arms since I pushed the rear axle back 4-5" or so... I still have to move the Upper Coil mounts back, no bigge tomorrows project, and maybe build an upper shock truss/mount.
Fuel tank is the biggest issue at this point, I need to figure that out, before she sees dirt.
Wheel base is 112” currently.
AW
Started to hack the driver rear quarter panels and lights…
Check these out ….
D60 Soild Axle Cover…
14bolt cover…
Installed covers…
All brakes are installed and bled. Front Line lock is installed as well.
I had some professional help today as well…
Also had a btf battery box show up… need more time for that install.
I received Claytons new Track bar bracket, and DPA… both installed with ease…
This corrected my steering issues perfectly…
And then painted my new Solid Axle Diff covers to match the rest…
Again with a monster helper…
Removed my fuel tank… and unsure of what the next step is… Cell or bring the stock tank up through the floor pan.
More trimming to the left rear quarter panel…
Progress is almost at a crawl lately or so it seems.
On a side note, what is best for sealing two pieces of sheel metal after stitch welds… it looks like OEM stuff is silicone like… any ideas ?
Thanks
AW
Got some minor stuff done like raising the fuel tank 8” or so… and some test flex…
Its getting there…
BeitragVerfasst am: 09.05.2007 14:28:04    Titel:
Jo...Das ist so ziemlich exakt der Umbau, den der RallyeJeep bekommen wird. Unterschied bei uns: Wahrscheinlich Coilovers. Aber der Rest ist in etwa gleich:
Full-Width Dana 44 Front und Rear, Proto Zeugs ohne Ende, Tri-Link hinten.
Wird aber auf 33" stehen bleiben, da ja für Rallye.
Habe nix zu meckern!!! Vertrau mir
BlueGerbil
1. Taxi
2. Toyota LeihCruiser
BeitragVerfasst am: 09.05.2007 14:46:49    Titel:
OMG! Kinderabeit und Nazi-Symbole... Wut
/ironie off, morgen ist ja erst Donnerstag
Im Ernst, sieht gut aus! Die Felgen könnten mir ja auch gefallen, aber so mit ohne TÜV traurig
Schwanz haben reicht nicht,
Wrangler_Rene
1. XJ, Wj, ZJ
BeitragVerfasst am: 10.05.2007 10:35:47    Titel:
Kennst du dich aus BlueGerbill? Iron Cross (eiserne Kreuz) hat nix mit Nazi zu tun.
Gab es auch schon lange davor.
Is bei denen auch in der Chopper Szene ein sehr beliebtes Motiv.
Das Auto ist cool.
bueti
Erntehelfer
BeitragVerfasst am: 10.05.2007 10:56:17    Titel:
lol, das ding is ja riesig :D
granviaje.ch
BlueGerbil
1. Taxi
BeitragVerfasst am: 10.05.2007 11:04:56    Titel:
Wrangler_Rene hat folgendes geschrieben:
Ob ich mich auskenne - keine Ahnung. Aber hattest Du meinen Hinweis gelesen "ironie off" ?
Aber da wir hier einige Forenmitglieder haben, die hinter allem und jedem eine tief-braune Verschwörung des militärisch-industriellen Komplexes im Allgemeines und des Springer-Verlags im Besonderen vermuten, konnte ich mir den Seitenhieb nicht verkneifen!
Also: Don´t worry - war weit entfernt davon, ernst gemeint zu sein.
Das Auto ist cool.
Keine Frage, sehe ich auch so.
BeitragVerfasst am: 10.05.2007 11:12:04    Titel:
Das Auto ist cool.
Come down, please. Das Thema ist und bleibt kein funnything.
Das Auto finde ich eher Banana
BeitragVerfasst am: 10.05.2007 11:13:38    Titel:
Ist doch ein astreines Fernreise- und Expeditionsfahrzeug mit Automatikgetriebe und Wandler O lappaloma blanke, i am just a bird in the sky Ich muss weg Knuddel
BeitragVerfasst am: 10.05.2007 11:25:35    Titel:
...da stehn sie wieder oben auf dem Berg... Ich muss weg rotfl
BeitragVerfasst am: 10.05.2007 11:34:21    Titel:
Hier ist ein Beitrag von U.B. als letzter den ich nicht lesen kann/ nicht angezeigt wird.
autoclaus
XJ-Ikone
1. AMC Jeep Cherokee XJ
BeitragVerfasst am: 10.05.2007 11:39:32    Titel:
Das Auto ist cool.
Nur mal so:
Das Hakenkreuz ist weit älter als das eiserne Kreuz - sozusagen uralt: die ältesten Funde stammen aus der Zeit vor 14.000 Jahren...
Es ist in allen Varianten mit typisch deutscher Dumm- und Blödheit verboten - weil man hierzulande lieber verbietet als sich damit auseinanderzusetzen....
BeitragVerfasst am: 10.05.2007 11:41:51    Titel:
Hat Uwe als offTopic markiert. Mal schauen, ob wir nen Bug haben, dass bei Dir (und anderen) die Anzeige von OT-Posts im profil abgeschaltet ist. Unsicher
bueti
Erntehelfer
BeitragVerfasst am: 10.05.2007 12:10:21    Titel:
autoclaus hat folgendes geschrieben:
ur mal so:
öhm, das swastika zeichen ist aber auf die andere seite rum wie das hakenkreuz...?
granviaje.ch
100516179834 Angriffe abgewehrt
Zeit für Seitenerstellung: 0.382  Sekunden
