Air Shocks
Tim.Tom
...und hat diesen Thread vor 4992 Tagen gestartet!
1. Lada Niva 1.6
BeitragVerfasst am: 27.08.2012 20:32:37    Titel: Air Shocks
http://www.offroadwarehouse.com/ecom/images/product/56206.34240.300x200.offroad_shocks-bs_20airshock.jpg
ELECTIONS: Products : Shocks : Fox Shocks : 2.0'' Non Coil-Over Air Fox Shocks
Part Number:
FOX980-02-019
Product Name:
Fox Shox 2.0 X 12.0 Air Shock
Our Price: $211.50
Free Shipping!
Description:
FREE Shipping! FREE First Revalve! (Up to 30 days after purchase)
Packed With 35 Years Of Race Winning Technology
100% Servicable And Tunable For Longer Lifespan
Zinc Plated Alloy Steel Body
6061-T6 Aluminum Components
Made in the USA
Invented by Bob Fox in 1974, air shocks offer infinite ride height settings with simple nitrogen gas pressure changes in addition to their compression and rebound damping adjustability. Air shocks provide a compact and lightweight alterative to Coil-Over shocks and are ideal for competition rock crawlers.
Smooth-bore, clear coated, zinc plated, honed seamless alloy bodies
Black Anodized 6061-T6 Billet Aluminum Hardware
1 1/4'' hard chromed 4130 alloy steel shaft
Race-developed high-flow piston design
Proprietary deburred valve shims
Redundant sealing pack system main seal, wiper seal, scraper seal
Specially formulated oil for ultimate performance at variable temperatures
Teflon-lined, heat-treated, alloy steel spherical bearings 1/2'' Bolt x 1 1/4'' Wide
Optional Spacer x 1 1/2'' Wide
Shaft: 1-1/4'' (1.250)
Finish: Black / Zinc
Ext. Length: 31.33
Col. Length: 19.33
Reservoir: -0
Hose: -0
Mounting: 1/2 X 1.250
taugen die was?
MFG Tom
Wer Rechtschreibfehler findet darf sie behalten! =)
BeitragVerfasst am: 27.08.2012 20:40:00    Titel:
Seltsame Frage. Wie soll man die beantworten. Unsicher
Du musst doch wissen, ob Air Shocks von Fox für Dich geeignet sind. Qualitativ sind die ganz weit oben. Fox halt. Nur kannst Du damit umgehen? Sie "valven", befüllen etc? Passen sie überhaupt für Deine Anwendung? Winke Winke
Tim.Tom
1. Lada Niva 1.6
BeitragVerfasst am: 27.08.2012 20:43:21    Titel:
passen würden sie und soviel wie ich mitbekommen habe muss man sich zum befüllen was bauen.
BeitragVerfasst am: 27.08.2012 20:51:01    Titel:
Gut, dann hast Du quasi keinerlei Erfahrungen damit. Das ist keine gute Ausgangsbasis. Unsicher
Ait Shocks einstellen will gelernt sein. Bauen muss man da auch nix. Wir haben das mal gemacht und wechselten später auf den korrekten Fülladapter, weils nur so gut geht. Aber Hier geht um die Kombination Druckstufe, Zugstufe, Ölstand und Druck. Und ohne jegliche Praxiserfahrung, stehst Du da vor ner großen Aufgabe. Eine Aufgabe, an der auch erfahrene Praktiker im automotiven Bereich schon gescheitert sind.
In diesem Fall kostet probieren ja doch etliches. Du hast allerdings auch Leute in Deutschland, die Fox nicht nur vertreiben, sondern auch erprobt einstellen können. Dann machts aber Sinn, die Shocks auch gleich dort zu kaufen.
Tim.Tom
1. Lada Niva 1.6
BeitragVerfasst am: 27.08.2012 20:55:31    Titel:
Gut erkannt mit dem keine Erfahrung Smile
Aber wenn man die hier kauft kosten die einiges mehr.
Matthias
Verdienter Held der Arbeit
2. Ovlov
3. Dnepr MT11
4. Honda Transalp
5. ½ Y60
6. ¼ DiscoIV8
BeitragVerfasst am: 27.08.2012 21:04:28    Titel:
Weil du die Erfahrung gleich mitbezahlst.
Du kannst eben hier kaufen und bekommst was fertiges, sinnvolles und passendes - oder du kaufst irgendwas, was du noch langwierig und evtl. teuer einstellen musst. Auf den reinen Kaufpreis kommt ja noch mindestens der komplette Einstellsatz dazu, Fülladapter, Öl und Gasbuddel brauchst du so oder so.
Entweder günstig und langwierig, weil du eben noch die Erfahrungen sammeln musst - oder etwas mehr zahlen und passend bekommen, die Möglichkeiten hast du unterm Strich. Und einfach einbauen, Gas rein und losfahren ist mit den Dingern leider nicht.
Für zweiteres ist http://www.ore-shop.de/ eine gute Adresse.
BeitragVerfasst am: 27.08.2012 21:13:22    Titel:
Ja
100503040 Angriffe abgewehrt
