Defender "Underdrive"
tim90
...und hat diesen Thread vor 4294 Tagen gestartet!
1. Defender 90
2. Defender 110
BeitragVerfasst am: 21.08.2014 16:36:04    Titel: Defender "Underdrive"
ich habe zu verkaufen von Ashcroft ein Underdrive. Produktbeschreibung:
http://www.ashcroft-transmissions.co.uk/the-underdrive.html
The Underdrive
We have for some time had demand for different gearing options of the low range on the LT 230 transfer case.
Historically this demand was for the "Rock Crawlers" in the USA and the "Glacier Crawling" in Iceland but due to the more recent trend in the UK and Europe of "Challenge" type events this demand has grown further.
The following specs can get confusing so a brief introduction may be useful,
The LT230 has a high and a low range, the high range ratio can be 1.003, 1.192, 1.206, 1.211, 1.222, 1.410 and 1.667 (the 1.192, 1.206, 1.211 and 1.222 can all be treated as the same), the low range on all LT 230 boxes is 3.321.
These numbers refer to the number of times the input gear must be turned to make the output flanges turn once.
Also note, all vehicles fitted with the LT 230 have 3.54 ratio diffs, this means the propshaft turns 3.54 times to make the Wheel turn once.
Bei Interesse bitte melden.
Gruss,
Tim
tim90
1. Defender 90
2. Defender 110
BeitragVerfasst am: 25.03.2015 11:20:37    Titel:
das Underdrive ist noch zu haben - Neupreis ist bei €2100, Verkaufspreis €1000 VHB
Gruss,
Tim
100516177410 Angriffe abgewehrt
