...und ich mach mir Sorgen wegen meinem Landy....
Oilworker
der mit den 3 Streifen
...und hat diesen Thread vor 7000 Tagen gestartet!
1. Project Wild Rhino
2. LR 110SW (RIP)
3. Chevy K5 Blazer (Kabul)
4. Serie I (SBH)
5. 101FC (St. Barths)
BeitragVerfasst am: 06.02.2007 22:03:57    Titel: ...und ich mach mir Sorgen wegen meinem Landy....
---------------------------------- Start of Quote (LR Addict Forum)-----------------------
G`day all, I had a bad prop day last week and here is the result, I have never seen one twist like this before.
I am not sure how this can happen, I suspect there must have been a small dent or stress raiser in the shaft to let go like this, admitedly I was at 11psi with a rear locker, with a chipped TD5 at about peak torque, landing after hitting a small clump crap in 3rd low, the landing was quite hard, but onto soft sand, so the stress ahould not have been to high going back up the drive line as the rear wheels would have also spun in the sand to some degree and not grabbed perect traction.
Talking to a freind out here who used to race a 4.6lt 110 has never snapped a prop shaft whist racing with a far more powerfull engine and subjecting his race car to more abuse than I could ever do.
I have temporarily fitted an old V8 shaft to keep me on the road, but the V8 shaft is only about 2/3 the thickness of the TD5 one, so am a bit worried about damaging this one as well.
My 1st thought was to just get another TD5 shaft and throw it in, but the question is after doing this once should I go for an up rated shaft or is this just a 1 off incident that wont happen again to a standard shaft.
My other problem is getting an up rated shaft out here in Dubai, I am going to see if I can get a heavier duty tube fitted and balanced locally, but I doubt I am going to be able to get one made locally, so it means getting one shipped in from the UK which is probably going to be quite expensive.
Any thoughts on idea on how it failed like this and if it could happen again would be greatly appreciated.
----------------------------------- End of Quote -----------------------
Der gechipte TD5 hat wohl mal ordentlich Kraft Grins Obskur Obskur Nee, oder?
BeitragVerfasst am: 06.02.2007 22:10:40    Titel:
Mit nem Knödli im Dödli ist Weiterfahrn nicht mögli Hau mich, ich bin der Frühling rotfl
Status: Online
BeitragVerfasst am: 06.02.2007 22:11:20    Titel:
Huch Huch
Frage mich gerade, ob das Material so weich sein muss, dass es sich so gummiartig verdrehen kann, ohne zu brechen Unsicher
basti
Querschläger
1. Wellblechhütte Td5
2. Elektrobaukasten VW Grand Cali
BeitragVerfasst am: 06.02.2007 22:16:12    Titel:
Boah, das sieht ja echt mal fies aus Obskur
Ich sag doch: Der Td5 ist ein geiler Motor mit ner Menge Bums YES YES rotfl
gsmix
1. Defender 90 V8 5.0 THOR
2. LR Ninety MY´87 200TDI
3. Range Rover Classic MY 77
4. ZIL 157KGD 6x6
BeitragVerfasst am: 06.02.2007 22:21:26    Titel:
Und weiter? Wo ist das Problem? Zu elbe (der GmbH) , Originalwelle aufn Tisch und gesagt die brauch ich für max Drehmoment und Gesamtübersetzung und mit nem soundsoviel längeren Schiebestück und soundsoviel größeren Arbeits-Winkel!
Dann passiert das nicht mehr! YES
Cheers
GSMIX
MOLON LABE
und
Terrier
Er Richet Bezwinger
1. Toyota HZJ 78
2. LR Defender 90
3. MB Viano 4x4
4. Outlander 800er
5. CBR 900 RR
BeitragVerfasst am: 06.02.2007 23:47:36    Titel: Re: ...und ich mach mir Sorgen wegen meinem Landy....
ja nun............., wat mut dat mut rotfl
und ich mache mir Gedanken über ein kaputtes Kreuzgelenk Nee, oder?
ja nee, is klaar !!
Knud
Füschmobb
BeitragVerfasst am: 07.02.2007 09:11:35    Titel:
Moin!
Das hat einer bei uns aus dem Club alle 1 bis 2 Jahre an seinem Nissan. Die Welle dreht sich solange auf, bis die aus der Verzahnung rutscht. Gibt es nur eine Dicke bei Wellen? Wir haben mal eine vom Suzuki unterm Landy gebaut. Hatte den gleichen Durchmesser....
cu Knud
Franky
Mönchshof Kellerschreck
1. Toyo Landcruiser KDJ 125 D4D
BeitragVerfasst am: 07.02.2007 09:11:58    Titel:
Huch Huch
High Flashi, Winke Winke
Denke mal, es ist besser wenn es sich verdreht. Reißt es, schlagen die Enden das ganze Fahrzeug unten zu Klump. (im schlimmsten Fall inklusive Fahrer ) Obskur
Schätze die Wandstärke des Rohres auf maximal 2,0 mm, vielleicht hatte es schon mal vorher durch Aufsetzen eine abbekommen, ist erstmal ne Beule oder Biegung drin , geht es ja ganz schnell. Ja
Interessant wäre jetzt zu wissen, wie es dem Getriebe und dem Differential geht.
Ich bin gespannt
Frank
DARC
Relaisloser Fichtenholzmagnet
1. Disco III SE Bj'05 Gelbe Plakette - Hmm, immernoch Ökoterrorist, oder?
2. Fiat 500 twinair Bj'11 Grüne Plakette - 20 Jahre alter Benziner oder wie ist das zu verstehen :-) ?
3. Burley Koosah Grüne Plakette - 20 Jahre alter Benziner oder wie ist das zu verstehen :-) ?
BeitragVerfasst am: 07.02.2007 09:33:10    Titel:
bei den nötigen kräften für so eine kaltverformung wäre meine sorge bzgl. einer neuen welle nachrangig.....das Diff würde mir sorgen machen....
Grüße Matthias
Aluminium + Fichte = magnetisch
BeitragVerfasst am: 07.02.2007 09:39:40    Titel:
Knud hat folgendes geschrieben:
... vom Suzuki unterm Landy gebaut. Hatte den gleichen Durchmesser....
Huch Huch Huch
Das Internet
Wohnort: Hinter dem Mond an der ersten Ampel links und dann etwa 2 Lichtjahre geradeaus bis zum Ende
1. Da könnte ich jetzt dieses und jenes reinschreiben
2. Was ich mal hatte, habe und vielleicht irgendwann haben werde
3. Oder aber auch was ich schon alles gefahren habe, als Mietwagen, Firmenauto oder überhaupt
4. Oder bayrisch-bengalische Wracks oder so
BeitragVerfasst am: 07.02.2007 09:44:16    Titel:
Unsicher Hätte nicht gedacht das die Suzuki Wellen so unterdimensioniert sind Ich muss weg
Twitter ist eine typische Erscheinung der Generation ADS & SMS. Für einen Brief zu faul, für einen kompletten Satz zu dumm und für korrekte Grammatik zu cool.
bluelandy
BeitragVerfasst am: 07.02.2007 09:47:03    Titel:
Er schreibt aber das es nach einem Sprung im 3 Gang der Untersetzung passiert ist
wenn Ruckartig ein Geschwindigkeitsüberschuss beim Aufkommen stattfindt kann so etwas passieren
Gruss Marcel
Ich will keine Garantie auf einen Morgen.
Ich weiß am Besten, wer ich bin.
Knud
Füschmobb
BeitragVerfasst am: 07.02.2007 09:54:03    Titel:
Maulwurf hat folgendes geschrieben:
Huch Huch Huch
Moin!
Croatia Trophy 2002. Die Kreuzgelenkhalterung vom Disco war zerbröselt. Welle durchgeschnitten, Welle von einer Suse "ausgeliehen" und durchgeschnitten, auf dem Boden liegend verschweißt, Flansch neu gebohrt und fertig. Bei jedem Stopp Schrauben nachziehen....
Beim Nissan gehen die im Trial kaputt. Ackerschlepperprofil schafft das auch, da braucht es keinen Sprung und keinen Dampf. Untersetzung und Gripp reichen...
cu Knud
ptos
5-Kilo-Pute
1. LR 110 SW MY02
2. LR 90 SW MY03
BeitragVerfasst am: 08.02.2007 12:41:30    Titel:
Das Bild von der verdrehten Kardanwelle läßt mich völlig kalt - hatte ich nämlich auch schon mal! Hau mich, ich bin der Frühling Hau mich, ich bin der Frühling Hau mich, ich bin der Frühling
Dazu reichte es, im ersten Gang Untersetzung auf die Wippe in Peckfitz fahren zu wollen - die Auffahrt war etwas ausgefahren und ich mußte alles geben - bis es einen fürchterlichen Kracht gab, weil sich die Welle aufgedreht und auseinandergezogen hatte - das freie Ende dongelte gegen den Unterboden. Obskur Ich hab die Welle ausgebaut und bin dann noch 340 Km nach Hause gefahren. Supi
Das Diff hinten hatte nichts abekommen aber das Getriebe hatte eine kleine Unwucht. (Wurde auf Garantie getauscht)
Habe jetzt eine verstärkte Welle von Elbe drin (Sonderanfertigung mt größerem Rohrduchmesser und dickeren Wandungen)
Vermutlich hatte die Welle unbemerkt eine kleine Delle bekommen und das hat gereicht... Hau mich, ich bin der Frühling
319289 Angriffe abgewehrt
Zeit für Seitenerstellung: 0.372  Sekunden
