Wrangler JK "Orange Crush", 7.0 Liter, 655PS, 40er
BlueGerbil
Le gerbil plus bleu
...und hat diesen Thread vor 6435 Tagen gestartet!
1. Taxi
2. Toyota LeihCruiser
BeitragVerfasst am: 15.10.2008 06:44:13    Titel: Wrangler JK "Orange Crush", 7.0 Liter, 655PS, 40er
Gebaut für die SEMA 2008 von www.cop4x4.com
http://www.cop4x4.com/orangeCrush/orangeCrush.shtml
Build Thread: http://www.jk-forum.com/showthread.php?t=54134
Motor and Drivetrain:
•7.0 Liter 426c” 655hp custom built hemi
•228/232 565/565 115LSA 111ICL
•Stage 2 Heads
•2.10/1.60 Stainless Valves
•Titanium Retainers
•Manley Springs
•Custom Locators
•Machined Locks
•Bronze Guides
•Viton Valve Seals
•CNC Ported/Hand Finished
•Billet Throttle Body
•545RFE Tyranny
•Larger custom Radiator/ fans/ ect.
•Currie Front Dana 60
•Currie Rear Dana 60
•513 gears
•Custom Heavy duty drive shafts
•SRT8 6 piston front Brakes and rotors
•Polished intake
•Custom Valve covers
•TeraFlex 6" Long Arm Lift
•Walker Evans 12” travel shocks
•2” airbags
•2” Wheel spacers
•6 lug axels
•Empire 22” black rims with orange inserts and carbon insert plates ½1/2” KMC
•40” Toyo MT’s
Outside Mods:
•Bushwacker fenders out of Carbon Fiber
•Entire Wild Boar Slant Back Carbon fiber
•TMD Custom Hood w/ Carbon vents
•Carbon Windshield pillars
•Anodized Black Billet Door Hinges, Door Handles, Hood latches, Antenna surround, front and side light covers, cop4x4 badge
•Custom painted hood with Orange Crush logo, tail lights, mirrors, plate holder, and all plastic
•Shaved Door Locks
•Mirror Mods?
•Stubby Antenna
•In Fab Custom Side steps
•TeraFlex Front and Rear Bumper/Tire Carrier, Glass Painted
•Vision X 84 LED 42” light bar carbon
Interior Mods:
•Custom Dash with Carbon accents
•Black/carbon door panels
•Custom Speaker Bar
•Pop up DVD/NAV/DC with amp, new speakers
•Headrest TV’s
•Black seats with orange suede insert
•Black headliner with orange suede panels
•Custom Arm Rest, Grab Bar, door pulls.
•Black billet shifters, seat adjusters, climate control knobs, air vents
•Carbon gage pod with gages
•Carbon Surf Board
Es wird wieder Nörgler geben, die Felgen zu groß, das Interieur zu "fancy" - sicherlich würde ich das Fahrzeug auch anders gestalten, wenn ich die Kohle hätte - macht aber nix, ich finde es trotzdem mehr als cool. Sinnbefreit, aber sehr sehr cool!
Schwanz haben reicht nicht,
Fux muß man sein!
BeitragVerfasst am: 15.10.2008 08:30:22    Titel:
Mich würde nur interessieren ob eine Dana60 das halten würde?
Abgesehen von der RadReifen Kombi (wirkt etwas "Niederquerschnitt) finde ich das schon interessant.
BlueGerbil
Le gerbil plus bleu
1. Taxi
BeitragVerfasst am: 15.10.2008 08:53:53    Titel:
"Die" Dana60 gibt es nicht.
Das geht bei 19spline los, dünnen Achsrohren, schwachen Achsschenkeln bis hin zu hier verwandten High-Tech-60er von Currie (oder eben die PNY/Klingel-Dynatrac-Variante).
Meint: Mit genug Geld kann man für fast jeden Reifen eine passende 60er kaufen.
5k$ kaufen Dir z.B. sowas: http://www.currieenterprises.com/CESTORE/product.aspx?id=2996
The RockJock® III high pinion frontend assembly for the 2007 and up Jeep JK includes the complete housing featuring the 65-45-12 ductile iron housing center (highest ground clearance 60 on the market), AR400 heat treated bottom skid plate allowing the axle to slide over rocks easily, 3" d.o.m. steel tubes, 1 ton inner knuckles, 5/16" thick heavy steel Diff cover, yoke (1310/1330/1350 optional), and all new heavy duty Currie Jeep JK suspension brackets mounted with Johnny Joint® equipped upper control arm mounts for maximum articulation. Axles shafts are the Currie performance 4340 35 Spline inner and outer with Spicer 1480 u-joints. Outer assemblies include 1 ton outer knuckles featuring Currie upper steering arm and ball joints installed, Currie exclusive 1 ton unit bearings with 5 on 5 1/2" Wheel bolt pattern and JK tone rings allowing for ABS and ESP retention, 13" vented rotors (over 1" greater diameter than stock for increased braking), zinc plated caliper brackets that retain the stock JK front calipers, Currie drive flanges or Warn premium manual locking hubs, and our heavy duty 1 1/4" o.d. 4130 chrome moly tie rod with tie rod ends. Additional parts needed to complete this unit are a high pinion Dana 60 ring and pinion gear set, Dana 60 35 Spline carrier of your choice, and a bearing & set up kit. Assembly labor of this unit is included in the price!
Zu den Niederquerschnittsreifen: Ich hätte wg. der Optik auch eher eine 18" Felge genommen. Ja
Fux muß man sein!
vinzenz
BeitragVerfasst am: 15.10.2008 09:11:21    Titel:
geiles Ding ! --- aber die Räder - grauenvoll
Oliver
Fromage-Offroad-Clique
Barde Grannus
BeitragVerfasst am: 15.10.2008 09:42:06    Titel:
Schönes Teil, und die Räder finde ich persönlich nicht so schlimm. Smile
grubber
Forums - Linguistiker
1. Pajero v60, Audi A4
BeitragVerfasst am: 16.10.2008 10:10:07    Titel:
was ist denn ein "carbon surf board" für ein interieur? Unsicher
sehr geil!
und das schräge hardtop hinten... Love it
lemitone
ultimate rollig
1. 130 TD4
2. 90 TDi
3. 90 TD5
4. Willys
5. GT4 RS CS
6. Caterham 620R
7. 964 C2 egmo
8. CS Independent
9. KTM 890R Rally
10. 701 Enduro
BeitragVerfasst am: 16.10.2008 21:06:31    Titel:
die räder sind nix - ansonsten liest sich´s lecker
BeitragVerfasst am: 17.10.2008 19:38:41    Titel:
Die Räder sind doch der Hammer. Bei dieser Geländefräse von Auto muss man sowieso nie Luft ablassen. Über das Felgendesign lässt sich natürlich streiten ...
lemitone
ultimate rollig
1. 130 TD4
2. 90 TDi
3. 90 TD5
4. Willys
5. GT4 RS CS
6. Caterham 620R
7. 964 C2 egmo
8. CS Independent
9. KTM 890R Rally
10. 701 Enduro
BeitragVerfasst am: 17.10.2008 19:40:02    Titel:
das felgendesign ging ja noch - nur sind die einfach ne nummer zu groß
BlueGerbil
Le gerbil plus bleu
1. Taxi
BeitragVerfasst am: 02.11.2008 10:34:03    Titel:
Dyno run
Aus Datenschutzgrnden, knnen nur angemeldete Nutzer das Video direkt hier sehen.
Mall crawling
Love it
Fux muß man sein!
BlueGerbil
Le gerbil plus bleu
1. Taxi
BeitragVerfasst am: 02.11.2008 10:35:29    Titel:
Aus gleichem Hause, nicht ganz so böse, beim Spielen in den Dünen.
Irgendwie gefällt mir die Anordnung von Reserverad und Kanistern... hmm...
Fux muß man sein!
BeitragVerfasst am: 02.11.2008 14:46:01    Titel:
@Jan: Den mag ich Supi
Dana 60 von Currie - Auch ein Traum YES
Aber mich hatte vor drei Jahren schon das Angebot für ne Ford 9" von Currie fast erschlagen und auch die Custom build Dana 44 Variante war kaum günstiger.
Hat halt mit ner Salisbury Achse (die ja gerade mal auf dem Gehäuse der D60 basiert) wirklich nichts mehr zu tun.
BlueGerbil
Le gerbil plus bleu
1. Taxi
BeitragVerfasst am: 02.11.2008 16:14:42    Titel:
Ich hatte im Zuge meiner krummen Dana30 eine Custom-44er bei Curries angefragt - 200$ teurer als eine vergleichbare 60er Hau mich, ich bin der Frühling
Fux muß man sein!
BeitragVerfasst am: 02.11.2008 18:06:17    Titel:
rotfl rotfl rotfl
Na dann los, lass uns Dana 60 kaufen gehen O lappaloma blanke, i am just a bird in the sky
BlueGerbil
Le gerbil plus bleu
1. Taxi
BeitragVerfasst am: 02.11.2008 18:23:09    Titel:
rotfl rotfl rotfl
I´m a 44 guy... Vertrau mir
Fux muß man sein!
100516179844 Angriffe abgewehrt
Zeit für Seitenerstellung: 0.473  Sekunden
